tz22da hydralics seem weak
   / tz22da hydralics seem weak #1
expedoman55
Bronze Member
Hey all. I have a tz22da 07 with 125 hours on it. Garage kept and loved. My question is this. It seems that when ever I use the FEL even just to move heavy items(within reason) the hydraulics seem very weak. The tractor has little to know digging capability even in low range. Is this just cuz it is a toy or is there somthing wrong.. Btw it has ALWAYS been this way bu I am so frustrated I usually just dont use the darn FEL..
   / tz22da hydralics seem weak #2
expedoman55,
Are you raising your engine speed?
On my TC34DA I have to raise the RPM's at 1700 - 2200 to operate the loader.
Check your owners manual for your TZ22DA.
   / tz22da hydralics seem weak #3
You can have presures checked on FEL to make sure they are within specs.
   / tz22da hydralics seem weak #4
With weight on the 3pt, my fel can lift a rear tire off the ground when digging too deep and trying to lift. It sounds like yours does need to have the pressures checked.
Mine is a TZ18.
   / tz22da hydralics seem weak #5
Is it also sluggish? Make sure you are seating your quick connects all the way. Easy to check, if all good, get the pressures checked after that.
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
Eagle Line 3pt Single Row Plow (A50123)
Eagle Line 3pt...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2012 VANGUARD 53FT DRY VAN TRAILER (A53426)
2012 VANGUARD 53FT...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
