TZ22 Wont Start No glow Plug light
   / TZ22 Wont Start No glow Plug light #1
MattRay
Frankfort, KY
TZ22DA
Tz22 will not start. The normal lights on the dash light up except the glow plug light. I have replaced the battery and the ignition switch. I have cleaned the battery terminals at the battery and frame. Thanks in advance for any help. I used the tractor to spread fertilizer. It ran fine. It seat about a month outside under a covered carport. Tried to start and it would not turn over.
I have checked all of the safety switches. The fuses are good. The battery is charged. Thinking maybe glow plug timer? I also need to check for inline 40 amp fuse, but we have not been able to find the fuse. I have a service manual, but we can not find that fuse?
   / TZ22 Wont Start No glow Plug light #4
Did you try jumping the starter? Touch a jumper (screwdriver often used) between post w battery cable on it and small post, both on starter solenoid. Make sure you're in neutral first. This will bypass all the safety switches and the key switch. Report back.
Jim
   / TZ22 Wont Start No glow Plug light #5
MattRay,
Did you locate the inline fuse?
What is your operation status now?
BarnieTrk
   / TZ22 Wont Start No glow Plug light #6
Wouldn't think you would need heat this time of year.
The lack of glow could be a symptom of a problem elsewhere. Can you tell if the fuel solenoid is open?
Those pesky electronic "controllers" seem to have a way of getting everything confused.
We did locate the fuse. It is good. The safety switches are all good. We replaced some relays by the fuses. Still nothing. Tractor is still seating in pieces on carport.
   / TZ22 Wont Start No glow Plug light #8
Is there a way you can bypass the safety switches just to get it to start....then back track from there?
BarnieTrk :confused3:
2007 Sterling L9500 (A55973)
2007 Sterling...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
