tyre wear
   / tyre wear #1
redman135
Veteran Member
nz
Case 105c
I live in a "keep left" country and accelerated tyre wear on the outside 1/2 of the left front tyre is common ie bald outside and approx 25/30mm of tread on the inside. Tractors observed are contractors units.
To those readers in keep "right countries". Do your tractors on high road use suffer from accelerated wear on the outside 1/2 of the right front tyre?
   / tyre wear #2
Yes, I just traded in a John Deere with an almost bald RF outside. Cars/trucks suffer from the same problem but not as noticeable if the tyres are rotated. Caused by the road crown ( slight slope engineered into roads to allow water to run off)
   / tyre wear
I had been told 2 theories.
1) road camber as you said.
2) axle is cambered for keep right market as keep left market is to small to be economic.
Unfortunatly rotating tractor tyres is difficult with fixed rims as you need to demount them and swap rims. Also under NZ law it is illegal to run directional tyres backwards.
1263 (A50490)
1263 (A50490)
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2014 716PT Homesteader 7'x16' Box Trailer (A52384)
2014 716PT...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
