Typical FEL Mount Bolt Torque?
   / Typical FEL Mount Bolt Torque? #1
mmranch
Crested Butte, CO
TYM T603
The manual for my FEL is basically a system description and parts list. There is no info about installing the FEL or bolt torque, etc.
I've got FEL mount bolts in the sizes of of 19mm, 22mm, 24mm gold color stamped with 10.0. These are for mounting the FEL mounts to the tractor.
What would be a reasonable torque for the 24mm bolt for example?
Thanks!
   / Typical FEL Mount Bolt Torque? #2
19 mm, 22 mm and 24 mm is the head size, right? That means it's a M12, M14 and M16 bolt respectively and the grade is 10.9.
There should be a chart for bolt torques on the manual. Anyways, here is a table for torques of metric bolts.
https://i.pinimg.com/originals/63/3e/bd/633ebd769611f5d828e58fdac6d0e945.jpg
   / Typical FEL Mount Bolt Torque? #4
Good-n-tight ... The real danger is a loose bolt. Just get a wrench and go over every bolt you can find. If you find one that turns with a firm tug... investigate the whole piece further.
torque charts for metric bolts class 10 posted previously
Thanks very much for all the info!
Thanks again.
   / Typical FEL Mount Bolt Torque? #6
Gutentight...........not like some......crossthread and then another 1/2 turn :ROFLMAO:
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
