Type of oil
   / Type of oil #1
MKF140
does anyone know what oil to put in a JD-Tek 3500 watt generator?
   / Type of oil #2
SF or higher grade (as per manufacturer). As said in the other post, I use Rotella-T 15W-40 in everything. If you want to use automotive oil, put in 10W-30 - can't go wrong with that.
JayC
   / Type of oil #3
These little gens just need clean oil. Strait 30 weight, 10W30, or 15W40 diesel oil will be fine.
Chris
   / Type of oil #4
It also helps to know what kind of environment you will be using this equipment in (temp wise).
DEWFPO
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
12 ft Chisel Plow with Rolling Baskets (A52128)
12 ft Chisel Plow...
POWER UNIT (A51243)
POWER UNIT (A51243)
Super Material Lift MH1000 (A52128)
Super Material...
Redneck Buck Palace 360 Hunting Blind (A50515)
Redneck Buck...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
