Oil & Fuel Type of oil to use
   / Type of oil to use #1
Ford4600
Ford 4600
What type (weight) of engine oil to use its a diesel
   / Type of oil to use #2
Best to look at owners manual. One machine may take 15w-40, while another may take 10w-30.
I don't have the owner manual and I can't find any info on the net
   / Type of oil to use #4
API classification diesel oil (CJ orCI, what ever the latest is) SAE 15W40 works for most diesels in ambient temperatures above ~32F.
   / Type of oil to use #5
If you really want to be sure, spend as few extra pennies and get synthetic diesel rated oil, it generally covers a much wider operating range. I use Rotella T6 in everything I own. You can get it at your local Walmart for about $20 a gallon
   / Type of oil to use #6
Some CJ oils are not backwards compatible to the CI-4 spec and are intended for Tier IV compliant engines only.
   / Type of oil to use #7
Here is the latest list I have been able to find. Some of my older diesel tractors had more latitude in oil specs than the new ones that have
tighter tolerances and need oils with better/quicker lubrication.
  • 2009_ENGINE_OIL_GUIDE.pdf
   / Type of oil to use #8
The API data in the post below yousr says that CJ's are backward compatible if used with ULSD fuels.
   / Type of oil to use #9
New Holland recommends it's new CJ oil only be used in Tier IV engines.
The cost of many CJ oils make the backwards compatible question moot. I won't be buying any until I have an engine that requires it. And that won't be any time soon.
Thanks for all the answers
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
