Oil & Fuel Type of oil to use
   / Type of oil to use #1
Ford4600
Ford 4600
What type (weight) of engine oil to use its a diesel
Thanks
   / Type of oil to use #2
Best to look at owners manual. One machine may take 15w-40, while another may take 10w-30.
I don't have the owner manual and I can't find any info on the net
   / Type of oil to use #4
Thanks
API classification diesel oil (CJ orCI, what ever the latest is) SAE 15W40 works for most diesels in ambient temperatures above ~32F.
   / Type of oil to use #5
If you really want to be sure, spend as few extra pennies and get synthetic diesel rated oil, it generally covers a much wider operating range. I use Rotella T6 in everything I own. You can get it at your local Walmart for about $20 a gallon
   / Type of oil to use #6
Some CJ oils are not backwards compatible to the CI-4 spec and are intended for Tier IV compliant engines only.
   / Type of oil to use #7
Here is the latest list I have been able to find. Some of my older diesel tractors had more latitude in oil specs than the new ones that have
tighter tolerances and need oils with better/quicker lubrication.
  • 2009_ENGINE_OIL_GUIDE.pdf
   / Type of oil to use #8
The API data in the post below yousr says that CJ's are backward compatible if used with ULSD fuels.
   / Type of oil to use #9
New Holland recommends it's new CJ oil only be used in Tier IV engines.
The cost of many CJ oils make the backwards compatible question moot. I won't be buying any until I have an engine that requires it. And that won't be any time soon.
Thanks for all the answers
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
Caterpillar 262D3 (A57148)
Caterpillar 262D3...
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
(4) 305/45R22 TIRES & WHEELS (A58374)
(4) 305/45R22...
