Type of oil for front axle on 4320
   / Type of oil for front axle on 4320 #1
bth
The owner's manual does not list the type of oil for the front axle on my 4320. It just says "recommended oil". Any ideas?
   / Type of oil for front axle on 4320 #3
On my 4700 it is the same as the Hydro oil, Low Visc. Hy guard.
David
   / Type of oil for front axle on 4320 #4
David
   / Type of oil for front axle on 4320 #5
bth,
This seems to be a common problem. Your answer is in the first 2 paragraphs in the Service Transmission section of your manual. It is located in the section before the subsection titled Checking Front Axle Oil Level.
The recommended oil is Hy-Gard, either standard or Low Viscosity depending on the expected air temperature.
This was confusing for me as well for my JD 4310. The wording in the 4310 manual is the same. The reference to the recommended oil means the oil specified at the beginning of the Service Transmission section.
Jeff
   / Type of oil for front axle on 4320 #6
bth,
Jeff
   / Type of oil for front axle on 4320 #7
If you want to go to a synthetic Amsoil is the ATH trans hydraulic 5-30.
It can be misleading in the manual the way they list it in with the tranny, sure confused me /forums/images/graemlins/grin.gif
   / Type of oil for front axle on 4320 #8
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52128)
Michelin CARGOXBIB...
2015 Nissan Sentra S (A50324)
2015 Nissan Sentra...
Toro Workman Utility Cart (A51694)
Toro Workman...
SET OF (2) UTV TIRES, 215/65-14 (A51244)
SET OF (2) UTV...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
