TYM273 just cut out
   / TYM273 just cut out #1
chrise
Essex, Mass
TYM 273
Hi
New battery installed (a saga, but done) - seems good - started it up - cranked a few times then just dead.
I did take the brake lock off during this but it is still dead after relocking.
I know it could be anything electrical but after the fuses what is most likely?
Chris
   / TYM273 just cut out #2
Had problems with wiring because of frame twisting. Had to tap up wires under dash. Was also blowing fuses. Will the starter turn the engine over?
No just went completely dead - no clicking for the warmup even - and battery is new and has plenty of current.
   / TYM273 just cut out #4
Check the (negative) ground from the battery where it attaches to the motor. If it is loose, what you described is what happens, just tighten it up on the motor end.
Thanks for the clue -was the +ve battery post loose - I had just installed a new battery a few mths ago so didn't think to check
   / TYM273 just cut out #6
I hate it when that happens. When I was in the Navy we always used the "Check the last thing you changed, fixed or touched" method.
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
FAE 150/540 LOT IDENTIFIER 124 (A53084)
FAE 150/540 LOT...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
UNUSED LANDHONOR LHR-PC90 HEAVY DUTY PLATE COMPACT (A51248)
UNUSED LANDHONOR...
