TYM273 just cut out
   / TYM273 just cut out #1
chrise
Bronze Member
Essex, Mass
TYM 273
Hi
New battery installed (a saga, but done) - seems good - started it up - cranked a few times then just dead.
I did take the brake lock off during this but it is still dead after relocking.
I know it could be anything electrical but after the fuses what is most likely?
Chris
   / TYM273 just cut out #2
Had problems with wiring because of frame twisting. Had to tap up wires under dash. Was also blowing fuses. Will the starter turn the engine over?
No just went completely dead - no clicking for the warmup even - and battery is new and has plenty of current.
   / TYM273 just cut out #4
Check the (negative) ground from the battery where it attaches to the motor. If it is loose, what you described is what happens, just tighten it up on the motor end.
Thanks for the clue -was the +ve battery post loose - I had just installed a new battery a few mths ago so didn't think to check
   / TYM273 just cut out #6
I hate it when that happens. When I was in the Navy we always used the "Check the last thing you changed, fixed or touched" method.
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
JOHN DEERE 5075GN LOT IDENTIFIER 115 (A53084)
JOHN DEERE 5075GN...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
11' CONTAINER (A51248)
