TYM T554 new owner
   / TYM T554 new owner #1
buckeroo
houston texas
TYM T554
After all the research and thought. I just purchase the new TYM model
tractor T554 HST with cab. Boy oh boy its was so smooth. Now I know going from
3 cylinder to 4 cylinder is a must. Its have an Yanmar engine and all the bell
and whistles. I have kubota bx25. Kubota b3030 cab.and jd 2355. But
this one will be my favorite. I have read alot of ppl report issue on TYM
Small model up to 433. My thought was because every manufacture
of tractor or car are put more effort into their bigger line. Just
like Mercedes for instances. Try to own one of their c class then
then you will know. Kubota or JD is no different. Cuz their profit
margins is greater on the more expensive line. Or maybe we
just over work those little one beyond their spec. Any how this
is my first post. But learn a lot from here. Thanks to all.
   / TYM T554 new owner #2
Congrads and welcome to the TYM family. I am sure you will be happy with it. I have a T503hst with cab and its been a great tractor. The main difference between tractors is the engine. Mine has a Perkins. With how cold it has been with winter I am glad I got one with a cab. Its nice to be able to use the tractor on a day with temps in the low teens and be so warm in the cab that I took my coat off.
   / TYM T554 new owner #3
Congrats on the new machine!
   / TYM T554 new owner #5
Ummmm. No pictures it didn't happen. Congrats on new tractor.
   / TYM T554 new owner #7
How does that Yanmar tier 4 engine run. Do you know how it regen's. Do you have to stop working and hit a regen button or can you continue to work it and it regen's. Different manufacturers have different ideas on this. Would like to hear your impressions on this machine. I'm in the market for a 40-55 hp tractor. Not sure on if I'll go tier 3 or 4. I really like the Cat/Perkins 43 and 50 hp engines. I know Yanmar makes a great engine too.
How does that Yanmar tier 4 engine run. Do you know how it regenp reviouss pu have to stop working and hit a regen button or can you continue to work it and it regen's. Different manufacturers have different ideas on this. Would like to hear your impressions on this machine. I'm in the market for a 40-55 hp tractor. Not sure on if I'll go tier 3 or 4. I really like the Cat/Perkins 43 and 50 hp engines. I know Yanmar makes a great engine too.
I personally don't know about CAT/perkin engine. So can not comment on that. Most my previous machines are deer
Kubota or yanmar engine. On the regeneration. I know yanmar engine
Was the first Tier 4 approve. ( that what I been reading)
On the regen's process yanmar engine design 3 process active. Passive and
manual. On the active process as long you ran your
tractor rpm at 2000 or above then the regen's process
will do its on its own. The regeneration light will illuminate
during the cleaning process. While you working.the regen's
Light will turn off by itsefl. On the passive regen's process
If the active process fail or ignore. The passive process will
Take over. The passive process will then try to pump fuel into
the exhaust to created enough heat to burn the particular from
the DPF. If this all failed, then manual process will need to be done.
on the manual process. You will need to park your tractor and run the
regeneration process.its will take 20 to 30 minute.My have been runing
the first regeneration process without stopping. Cuz I always ran my at
2000 rpm. Try not to ran at ide rpm for long time then the active or passive
will failed. Hope this help.
Note on the yanmar tier 4. The first 50 hrs service like any brand
tractor. The interval service is 500 hrs after that. Its is a big difference
then the traditional tier 3 which is 100 or 200 hrs. Like my kubota
or JD.
1608 (A57192)
1608 (A57192)
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2013 BMW X5 AWD SUV (A56859)
2013 BMW X5 AWD...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W4DT2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
