Tym T353 Oil leaks
   / Tym T353 Oil leaks #1
Davedur
Tym353
Hi all, I wonder if someone can help please.
I have just bought a second hand TYM T353 Manual (2012). There is a significant oil leak from the offside back axle and a smaller leak from the one on the other side. I think i am going to have to replace the shaft seals. Does anyone know if this can be done without dismantling the whole axle assembly or can I just remove the shaft seal housing? If I have to go into the axle assembly, apart from seals, are there any parts i need before i start? (Gaskets? etc). Thanks in advance. Newbie to the whole tractor thing.
Thanks ptsg for getting back so quickly.
I had a quick look last weekend and feared that would be the case. Looks a tricky job but i'll give it a go.
   / Tym T353 Oil leaks #4
Tricky part usually is the bearings. If they are a press fit in to the shaft, can be a pain to get out without proper tooling.
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
