Tym T353 Oil leaks
   / Tym T353 Oil leaks #1
Davedur
Tym353
Hi all, I wonder if someone can help please.
I have just bought a second hand TYM T353 Manual (2012). There is a significant oil leak from the offside back axle and a smaller leak from the one on the other side. I think i am going to have to replace the shaft seals. Does anyone know if this can be done without dismantling the whole axle assembly or can I just remove the shaft seal housing? If I have to go into the axle assembly, apart from seals, are there any parts i need before i start? (Gaskets? etc). Thanks in advance. Newbie to the whole tractor thing.
Thanks ptsg for getting back so quickly.
I had a quick look last weekend and feared that would be the case. Looks a tricky job but i'll give it a go.
   / Tym T353 Oil leaks #4
Tricky part usually is the bearings. If they are a press fit in to the shaft, can be a pain to get out without proper tooling.
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2011 Ford F-150 Pickup Truck (A50323)
2011 Ford F-150...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
