TYM/Mahindra vs TYM
   / TYM/Mahindra vs TYM #1
2manyrocks
Super Member
I've been thinking I'd like to get a cab tractor with AC for keeping my fields cut during the summer. I'd also like 4 wheel drive. My current field cutting tractor is a Mahindra 3525 open cab 35hp 2 wheel drive. One good thing is there is no emissions garbage on my 3525. I'm running a 6' rotary cutter. It takes a while to cut all my fields, but 35hp is enough with a gear drive tractor.
A Mahindra 2555 cab tractor with 134 hours is for sale near me for $28,000. Tractor.Data says its made by TYM. TYM 474C is advertised for $32,000 new by one dealer. Another advertises a T574C for $35,700. There's also a T394C listed for $29,900, however, I see the 474 recommended more over the 394 on TBN for the price difference.
The Mahindra 2555 is evidently a 55hp tractor. Sort of looks like the best deal price wise, but one concern is buying a Mahindra that is apparently made by TYM makes me concerned whether Mahindra will support it with parts later unlike buying a TYM to start with?
   / TYM/Mahindra vs TYM #2
Tough choice but if it were me I would go with the TYM for the Kukje engine.
Shuttle shift or gear drive?
   / TYM/Mahindra vs TYM #5
I prefer gear with shuttle over HST but that is a personal choice depending on what you will be using it for.
Bush hogging/pasture clipping.
   / TYM/Mahindra vs TYM #7
Brand new T574H was just under $30K. Another $5k for a cab.
That's a 55 HP machine with the Kukje engine and a full warranty and no chance of being orphaned. I would not buy used unless I personally knew the seller.
I saw a 2010 TYM T451 with 866 hours listed for $23,400 at a dealer. The description says the AC isn't working because it needs a new compressor. Having a cab without AC in Middle TN would be much worse than an open station tractor because of the heat build up. Although I think it would be really nice to have a new tractor with a cab and working AC, now I'm having reservations about spending $32 or 35k on a new tractor just to have comfort that might or might not be working in 10-15 years.
   / TYM/Mahindra vs TYM #9
The T474 is perhaps TYM's best seller besides the T25/T264, I've got 332h with no problems. The Kukje engine is very simplistic and reliable.
If we got snow like that, having a cab for heat could be worth it regardless of the AC.
That's a nice picture.
East Tri Axle Semi Dump Trailer (A50774)
East Tri Axle Semi...
2006 TOYOTA Highlander SUV (A50324)
2006 TOYOTA...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
