TYM LT200 FEL, Hydraulic Fittings Type
   / TYM LT200 FEL, Hydraulic Fittings Type #1
jigs_n_fixtures
Veteran Member
Salmon, Idaho
TYM T233 & T293 CAB
I have a TYM T233, with the LT200 FEL. I’m getting ready to add a diverter valve to run a grapple. Max hydraulic pressure at the relief valve is 2500-psi.
Does any one know what thread type/size the stock tees, and nipples are?
I’d like to us hard lines as opposed to hoses as much as possible: Is there a good online source for hydraulic hard line tubing? Any alloy which is easier to shape and flare I should be looking for?
   / TYM LT200 FEL, Hydraulic Fittings Type #2
jigs, I've got the LT200 on my 273; I bought my diverter valve from Kens bolt-on hooks and it works just fine. Was pretty much a plug-n-play install. I have 1/4" rubber lines running to the bucket end and have perfect speed and control. I found that ISO 7241 series "A" "poppet style" quick disconnects interchange with the Kwan Kwang 09 PT 3/8 that were originally on the system. Be well aware that a Gorilla did the install of the originals! It took me and a 6' cheater pipe to break loose the fittings!
You are going to need learn a completely new language when you go to purchase hydraulic fittings!
1/4" hose translates into (-5) fittings and there are a number of different (-#) fittings available!
I can't answer to the hard lines question as I simply went with rubber as it was far easier.
Good luck, Greg
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2004 Mercedes E320 Sedan (A50324)
2004 Mercedes E320...
2014 Honda Accord Sedan (A50324)
2014 Honda Accord...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
