TYm HST oil
   / TYm HST oil #1
dieselsmoke1
Platinum Member
Eastern North Carolina
Mahindra 2810HST
Thinking about going to synthetic on the Mahindra 2810HST, which is essentially a TYM with red makeup on. Has anyone tried synthetic in the tranny and were the results good?
   / TYm HST oil #2
Be careful, unless the engine was specifically designed for synthetic oil you may lose your seals, and it may leak badly. Mobile 1 red grease however is a great replacement for lithium or common grease. That you can safely use.
If your smoking check your fuel injectors and pump timing.
WB Mower (A50120)
WB Mower (A50120)
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
2014 Ford Escape (A50323)
2014 Ford Escape...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
