TYM glowplugs
/ TYM glowplugs #1
ALKY
bedford co. pa
tym 233hst
I have a 233 with a mitsibishi diesel. It won't start cold w/o ether. the bussbar on the glowplugs shows battery volts. Does this mean the plugs are bad? thanks in advance.:)
/ TYM glowplugs #2
How long are you letting them heat up? Many take as long as 30 seconds. If you have voltage of 7+ volts for that long, and you can't feel them heating up, then they are bad.
Tom
/ TYM glowplugs #3
most of the tractor companies are giving a strong recomendation against using either in modern engines. I would guess Mitsu is the same.
RAMMAX 3324 VIBRATORY TRENCH COMPACTOR (A63290)
RAMMAX 3324...
John Deere 6110M (A60462)
John Deere 6110M...
2021 John Deere W48R Walk Behind Zero Turn (A63116)
2021 John Deere...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
(APPROX. 5) 28' - 29GA BLK TIN (A63290)
(APPROX. 5) 28' -...
John Deere 612 2-Bottom Plow (A63116)
John Deere 612...
