Tym 503 won't turn right
   / Tym 503 won't turn right #1
glamm98
Spring hope
tym 503
Turns left and back straight fine but will not turn the wheels to the right. Any ideas what mite be wrong.
   / Tym 503 won't turn right #2
Have you tried raising the front end up and see if it will turn? Could be something binding in the front end not allowing it to turn.
   / Tym 503 won't turn right #3
Check to see if your power steering hydraulic cylinder is still connected on that side ... Make sure it's not leaking.
   / Tym 503 won't turn right #4
I had a tractor that the steering turn stop nut loosen. Then the bolt backed out over time. Turning to that side kept getting less and less. I thought it was in the steering column, but at last it was something simple. I tightened up the bolt and stop nut, and I was back in business.
Kubota Salt-Spreader (A52384)
Kubota...
2023 Icon I40L Electric Cart (A50324)
2023 Icon I40L...
40' Sea Container (A50774)
40' Sea Container...
2015 Chevrolet Equinox 2LT SUV (A50324)
2015 Chevrolet...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
