TYM 474 automatic throttle
/ TYM 474 automatic throttle #1
Matune
Chewelah
2020 TYM 474
My automatic throttle quit working with the pedals. The mechanical throttle works great.
it’s out in the woods so I hate to haul it into the dealer who said, “I have heard of that happening, check wire connections to see if a twig unhooked something.”
so at this point I shall have to haul it in.
I guess I’m hoping someone has an idea....I could find no disconnected wires or loos connection s thus far...
i normally don’t use the automatic throttle anyway, buts it’s new so it should be working..,
/ TYM 474 automatic throttle #2
If your TYM has the Kukje engine, then it should be all mechanical.
For the throttle, you should have two cables. One for the hand throttle and another one for the HST linkage.
You may want to look under the tractor to see for any obvious fault after tracing the route of the cables.
/ TYM 474 automatic throttle #3
Yes, there should be a linkage from the pedals to the injector pump, the T474 shop manual is on the Facebook group if you need diagrams etc.
Thank you!
I’m not finding a service manual so would sure appreciate a link...
Thank you! That is A very helpful download.
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
2002 MACK RD688S ROLL OFF TRUCK (A67714)
2002 MACK RD688S...
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
PORTA POTTY (A67714)
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
CAT D9H 4BBL Multishank Ripper (A68134)
CAT D9H 4BBL...
