TYM 394 HST dash went out...
   / TYM 394 HST dash went out... #1
The Chairman
TYM
I have very few hours on this three-month-old tractor and the dash went out. No tach, no fuel gauge. The idiot lights come on when I first crank it, so not everything is dead... just the graphics. Where are the fuses and why can't I get my hood to pop?
   / TYM 394 HST dash went out... #2
Pull the hood release harder. The fuse is in a little box behind instrument panel.
   / TYM 394 HST dash went out... #3
This is from T293 manual Screenshot_20180711-215632_Hancom%20Office%20Editor.jpeg
   / TYM 394 HST dash went out... #4
TYM had some issues with the dashes going out. I believe they fixed the issue. I think you need a new one.
Thanks! I've been distracted with other chores, but this is high on my to-do list.
   / TYM 394 HST dash went out... #6
it should still be under warranty, so you should let your dealer fix it with the update, so it don't happen again..
   / TYM 394 HST dash went out... #7
Do I understand this thread right, my dash lights only light up with all of the information just when I start it but as soon as it is running they immediately all go out -should there be icons lit so you can see what is going on when it is running?
   / TYM 394 HST dash went out... #8
My mahindra 2538 is the same tractor and my lights all go out when running.
   / TYM 394 HST dash went out... #9
My hood release also sucks . if it gets dirt and crud in there it wont allow the lever to move over far enough. i tried lube and that made it worse now i keep it dry and blow it out with air and it opens good now.
   / TYM 394 HST dash went out... #10
I just had the same thing happen with a Cabelas LM36/T354 with 50 hours on it looks like I will be replacing the panel..
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
