TYM 353 no forward and reverse
   / TYM 353 no forward and reverse #1
brobo
Spokane
Hi everybody need help if you can. Like I said I have a TYM 353 with hydro static drive, last night I lost forward and reverse. Push peddle to floor nothing happens either way. I looked under at the linkage but I must have missed something, everything looks hook up. Has anybody had this problem before, If so please let me know. Thanks for any help you can give me. Mark
   / TYM 353 no forward and reverse #2
I might be stating the obvious but are you still in gear? My 353 occasionally will slip out of gear.
Thank you but yes it is in gear
   / TYM 353 no forward and reverse #4
Not familiar with the 353, so just guessing - 1. not quite in high or low range (stuck in between) 2. drive shaft and or u-joints broken 3. low fluid or plugged filter.
Had some drive shaft problems with my 273 but that would be pretty obvious when it went.
Thanks everybody for your help. Found out what happen. Farther under neighteh the tractor just in front of the trans. filter there is a adjustable shift rod it came loose. Needed a nut to fit it. Saved over 200.00 thanks again
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2000 Ford F-650 (A50120)
2000 Ford F-650...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
