TYM 353 HST GEAR QUESTION
   / TYM 353 HST GEAR QUESTION #1
astro1949
my 353 haes 3 gears (L M H). i use Medium to cut grass.....am i hurting the transmission ----when should i use L or H ??
thanks
bob
   / TYM 353 HST GEAR QUESTION #2
Medium is good for about 90% of all jobs such as mowing, FEL etc. Low is used when you need precise slow motion or you need large traction. High is used for transportation on roads.
When mowing run the engine at PTO speed. When doing other jobs run it at least 2000 rpm.
   / TYM 353 HST GEAR QUESTION #3
^^ What he said.
James K0UA
Thank You----that helps me understand it is not like a Car tranny.....
bob
   / TYM 353 HST GEAR QUESTION #5
bob
Not really at all like car or truck transmission.. If you are in MED and start to bog down, back off of the hydro pedal for more torque, and less speed. This is counter intuitive, as most people when bogging down, will stomp it harder, but that is the wrong thing to do. If the hill is really steep and the load really heavy use LO to start with.. It can be dangerous to change ranges on a steep hill.. you can have trouble switching ranges, and get it in neutral, and whee... down the hill you go if you are unprepared.. if you must switch ranges.. Put you foot on the brakes hard. Hope it is in 4wd too for better braking action.. Best thing is to be in the range you need to be before ascending or descending hills. If you have hydrostat+ (kubota thing) you can "downshift" on the fly with a steering column mounted lever for more torque. It has a "subrange" within each range it doesnt actually change any gears, but it changes the angle on the swashplate... But most tractors do not have this ability.
James K0UA
A1 Terminator 3pt Blower w/ 60 Gal Tank (A50120)
A1 Terminator 3pt...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2025 Kivel 48in Tractor Loader Fork Attachment (A50322)
2025 Kivel 48in...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
