Tym 273 glow plugs
   / Tym 273 glow plugs #1
Deniza
Tym t273
Does anyone know what the part # for the glow plugs on the Mitsubishi s3l motor used by TYM? I can't find it listed in any catalogs. I would like to buy it threw my local napa store. Thanks in advance. Any other part # from NAPA would be very helpful. Fuel, air , etc.. My TYM dealer closed up shop. Thanks again for you'd help.
   / Tym 273 glow plugs #2
TYM Part # 32A66-03100
Thanks crossed the number over to NGK. Have them coming for the weekend. Let you know how they work out. Thanks for all your responses!
   / Tym 273 glow plugs #4
Do you mind sharing the NGK# ?
   / Tym 273 glow plugs #5
Do the glow plugs give much trouble? I know a lot of people have had trouble with the relay. I have 350 hours and have never had any problems with either.
I think I got the relay wet one time, then ran it with the light on. That said I just ohm check them and had to replace one. Started much easier. I have about five years into it.
   / Tym 273 glow plugs #7
Hi Deniza,
Like Myyaz33, I too, would appreciate it if you'd share the TYM Glow Plug cross reference to NGK #? Anytime anything can be cross ref'd it's good knowledge to know. Thanks. Greg
   / Tym 273 glow plugs #8
I had a lot of trouble with cold starting my TYM273. Finally completely burned up the glow plug relay (so bad they had to replace the plug and end of the main wire harness). Thank God for the warranty. At the same time they replaced the battery cables with cables nearly twice the diameter. Now I do not even have to plug in the block heater in cold weather to get it to fire right up. Good luck and please pass on the cross reference number for our own records.
   / Tym 273 glow plugs #9
Older thread but worth updating.
NKG Part# Y-114T
That is for the Mitsubishi K2(S) and K2 B/C.
   / Tym 273 glow plugs #10
Just following up on the new glowplugs. Did you fit the NKG y114T type and what are the results??
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
Adams Conveyor (A51039)
Adams Conveyor...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
6 Trench attachment (A50322)
6 Trench...
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
