TYM 264 Oil Filter
   / TYM 264 Oil Filter #1
ckunzmann
Athol, ID
TYM 264
Absolutely green rookie -
Got a TYM 264 tractor and I am at the 50hr oil change mark. What is an equivalent oil filter that is readily available for a TYM 264? Heaven forbid that TYM will publish part numbers in their user manuals...
   / TYM 264 Oil Filter #2
Your TBN profile does not list your location..... if it did, you would likely get more help
If you are anywhere between Pennsylvania and Florida, and a bit further West, you should go to a Rural King store.
Their RK tractors are built by TYM, and use the same engines.
RK stores will have, or can get, filters for TYM machines.
   / TYM 264 Oil Filter #3
The TYM T264 is not the same as the RK 24. This one uses Kukje engine, while the RK 24/TYM T254 uses Yanmar engine.
Sorry, I have now updated the location. But in short, up in Northern Idaho, just north of Coeur d'Alene.
Is there an equivalent that I can go to an O'Reilly's or an AutoZone to pick up ?
I can also place an Amazon order but I am after particular part numbers.
Also is there an part number for Transmission Fluid ?
Thanks for the assistance
   / TYM 264 Oil Filter #5
I ran that model through Wix lookup and got this result;
Sorry, but there are no filters for this vehicle in our records.
   / TYM 264 Oil Filter #6
I would use factory filters at least until the warranty is over....:2cents:
   / TYM 264 Oil Filter #7
Have you tried contacting your dealer? He should be able to provide all of that info and maybe ship what you need directly to you as well.
I wouldn't go with aftermarket hydraulic filters. I don't know on TYM exactly, but on other brands you burn the hydraulic pumps by using aftermarket filters that look the same but are not the same inside. Just be aware of that.
   / TYM 264 Oil Filter #8
X2 on checking with your dealer!. I would guess that is Jordan Sales in Post Falls, Terry has been great helping me with parts etc. I bought my filters from him and premium hydraulic fluid elsewhere. I just replaced a fuel filter through them and it was a name brand not TYM.
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
Polaris Side by Side (A50324)
Polaris Side by...
