TYM 25 issue
/ TYM 25 issue #1
nkhd
cabelas lm25
Tractor is a Cabelas LM25 which is made by TYM. I purchased it cheap as not running had 42 hours but owner overheated due to rats eating wires and cracked head. a mechanic had it planning to fix it and didnt. however he left off the fuel lines going to the injection pump...
so long story short replaced head, injectors, pump, thermostat, fixed wiring issues. Tractor is running fine. Except...
when going forward it will run for 100 feet then die suddenly. Cranks right up and goes forward a short distance and dies. engine does not sound loaded up Reverse i can drive anywhere and everywhere and no problem.
any thoughts as to what might cause this?
Thanks in advance
/ TYM 25 issue #2
That will make a good tractor for back dragging. :ROFLMAO:
Strange issue for sure but I would suspect a safety circuit problem. A switch somewhere out of adjustment or wired incorrectly?
Maybe a test would be to start the tractor then unplug the shut off solenoid. If the tractor stays running then drive forward and see if it dies. If not you know something somewhere is sending a signal to the shut off solenoid.
/ TYM 25 issue
back dragging for sure. I feel like tow mater always going in reverse. Thanks for the suggestion - where would the shut off solenoid be located? is that on the injection pump?
/ TYM 25 issue #4
Yes it is on the injection pump. Hope that helps.
/ TYM 25 issue
didnt make a difference did notice when driving backwards the oil light flickering (not flashing). thinking its a wire that i missed
going to get a couple new sensors and pull the harness (ughhh)
/ TYM 25 issue #6
How many wires going to the cut off solenoid? If 2 it should have not died of it is a wiring issue. If 3 wires it should have died when you unplugged it.
Bale Ring (A66408)
Bale Ring (A66408)
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59914)
2021 KENWORTH T680...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
TRUCK BED, TRAILER FRAME & BUSHHOG (A62613)
TRUCK BED, TRAILER...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
