ty395i
/ ty395i #1
h20s
avenger , 54 Ferguson
Need help just changed the hydraulic pump on my ty395i and now oil is coming out of the vent tube and the dip stick ?
/ ty395i #2
/ ty395i
So what happened is the backhoe came unhooked deadheading the pump and spilting the frist pump. Got a new pump made sure everything was hooked up now the new pump blew out the seal ? Could the deadheading the first time broke something else
/ ty395i #4
Do you have quick-connects? They have a ball valve that keeps fluid from leaking out when they're not connected, sometimes the ball sticks. Some Jinma owners take the balls out.
The Jinma doesn't have a built-in pressure relief valve. The pump moves a constant volume of fluid on every rotation of the shaft. If there isn't a clear path from inlet to outlet of the pump the pressure will build until something gives. Usually "something" is expensive and hard to replace.
Is your backhoe running off of the tractor hydraulics, or do you have a separate pump for the backhoe?
/ ty395i
Back hoe is run off tractor hydraulics, starting to think the new pump rotation is wrong is there a way to to tell ? The pump I bought said the direction can be changed. If so how do you change it
/ ty395i
The pump was bought from circle g tractor , the pump is cbn 316 and mounts on the right side on engine in front of the starter The old pump was cbn e314
/ ty395i
K so I think the problem is the rotation of the pump, which way are the E or W gaskets tips supposed to be poniting towards the in or out
/ ty395i #9
I don't think you can change the rotation of the pump unless you change the rotation of the engine.
/ ty395i
Problem sloved , The e seals were in wrong:thumbsup:
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
DIAMOND TOOLBOX (A68842)
DIAMOND TOOLBOX...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2011 CARGO CRAFT ENCLOSED GOOSENECK (A67714)
2011 CARGO CRAFT...
2017 CATERPILLAR 249D SKID STEER (A65056)
2017 CATERPILLAR...
PORTAPOTTY TRAILER (A68842)
PORTAPOTTY TRAILER...
