TY 290 crankshaft nominal sizes
   / TY 290 crankshaft nominal sizes #1
Tbrendal
Alberton
Rhino 224
Hello to all!
Was wondering if anyone had the nominal crankshaft sizes for a TY290 2 cylinder in a Rhino 224, Same as Jinma 224 v intage of 1996. I spun a rod bearing and the machinist needs these sizes to help me fix the crank. I have a book for the engine, however they only list clearances.
Thanks!
   / TY 290 crankshaft nominal sizes #2
The plan is to grind it to remove damage then he will make new bearing for it, It takes the guess work out of it if you know the original size. If this does not work out I will buy a new one from you guys.
If I do buy one from you guys how would shipping be to Alberton Mt. 59820?
The hobbs meter has never worked so i really have no idea. I've had the tractor for about 5 years and use it quite a bit for snow removal, cleaning out barns, hauling logs etc... I really need to get it going as spring is coming!!! Ill talk with the shop tomorrow and if they don't have a good plan I'm just gonna order a new one.
Quick question for all you smart guys out there. I am ordering parts to put this thing together and have seen 2 styles of head gaskets offered. 1 is a copper sheet type (this is what came off of it) and a composite type. Which is correct?
   / TY 290 crankshaft nominal sizes #9
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
CHERRY PICKER AND TRANSMISSION JACK (A53843)
CHERRY PICKER AND...
5th Wheel Travel Trailer (A51694)
5th Wheel Travel...
