tx1500 injection pump o rings
/ tx1500 injection pump o rings #1
trx400r6
Buffalo, MN
Bolens g174 / Iseki tx1510/2160 K3B engine
hello,
would anyone have a part number for the o rings that go on the lower "nut" where the hard lines attach to the injection pump?
o ring would go around the shoulder of the fitting with the arrow pointing it in the picture...
motor is a Mitsubishi K3B 3cy in a bolens g174 (tx1500f)
thanks guys!
/ tx1500 injection pump o rings #2
Here are a few pages from parts manual
thanks fxrs55! I don't have a parts manual, just a service so theres no part numbers listed... and my manual if for a twin cylinder ke70 and ke75... diddnt know that when I ordered it...
this is what I needed! no the hard part finding them or the right size listed anyway...
thanks again sir!
/ tx1500 injection pump o rings #4
Iseki didn't make the inj. pump.. more than likely its a Zexel pump..
IF the dealer cant get the parts from Iseki or tells you their back ordered or some crap like that.. they are redily available from ANY injection shop.. BUT your gonna need the #'s off the inj. pump.. they are stamped in the mounting flange just left or right of the fuel inlet bolt..
OR on the back side.. gonna need a mirror for that..
I knew iseki diddnt make the pump. But figured getting their number would be the best place to start... I just had no idea of it was a excel or bosch or what...
There are a few numbers stamped on it and it has a brass tag with stamping on the back side but like you said I'll have to take my mirror on a stick home from work to see what it says...
I gotta see what's around my area for injection pumo services too...
Thanks pump guy!
/ tx1500 injection pump o rings #6
IF you can get the #'s, I'll try to de-code them & give you the P# of the orings..
THAT WAY they'll be easier to find..
Alright this is what I came up with for numbers so far.
049500-5160
Which seems to be a sensor pump by my searching... this number is stamped into the small oval plate on the back side...
1011? Hard to read but that's stamped on the top line of the oval tag as well.
Also there is a logo stamped on the little oval tag it's ND but kinda morphed together as a logo.
27153 is stamped into the casting of the pump itself but I couldn't find anything with that number.
There is another number on the small oval tag as well a really long teeny tiny one I can't make out with the mirror I had I'm gonna try to find a magnifier mirror and see if I can get that number yet.
All help much appreciated if these number mean anything to you. Otherwise I'll just pull it apart and try to go by ID and OD and thickness.
/ tx1500 injection pump o rings #8
Here is a page from the AGCO Partsbooks.com web site.
The White field boss 16 is almost the same as your tractor.
You can order parts for white tractors at a Massey Ferguson
dealer. Massey dealers get their parts from AGCO. I have
bought parts for my TX1300F from a Massey dealer
here in NJ. A Massey Ferguson 1120 tractor is also
a close match. I have bought my parts with part numbers
from the 1120 or the Field boss 16.
Also check this link
White 16 Field Boss | Tractor & Construction Plant Wiki | FANDOM powered by Wikia
/ tx1500 injection pump o rings #9
That is a NipponDenso pump.. or Denso as its called now..
The problem w/ a mirror is things get turned around>> I think its a 094500- maybe that's why its coming up as a sensor..
I'll look it up when I get to work.. TPG
/ tx1500 injection pump o rings #10
Oring p#> 090139-0400
Delivery Valve gasket#> 090137-0130
Lube orings w/ "something", I use vasoline.. & the delivery valve holders MUST BE TORQUED to 30-35 FTLBS..
Hope this helps.. Good luck.. TPG
the bolens is now LEAK FREE! thanks for all your help pumpguy! I was able to take the part #s you got for me and cross them over to Kubota part #s and get them from the local Kubota dealer 15 miles away so pretty easy... and found a very nice parts guy that actually know what hes doing for once so will be able to cross over lots other parts in the future now if need be...
thanks again guys!
/ tx1500 injection pump o rings #12
I had a problem with that center nut as well. Mine tightened up and stopped leaking however. Maybe I am on borrowed time.
2017 Ford F-650 Mason Dump Truck (A59230)
2017 Ford F-650...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
Kubota LX2620 (A53317)
KMC 9' CLEANER (A60430)
KMC 9' CLEANER...
WHIRLPOOL REFRIGERATOR/FREEZER W/ICEMAKER (A60432)
WHIRLPOOL...
CLUB CAR 272 CARRYALL GAS GOLF CART (A60430)
CLUB CAR 272...
