Two speed Electric motor question
   / Two speed Electric motor question #51
I run about 25,000 gallon salt water on a single speed with regular timer. Works fine.
   / Two speed Electric motor question #52
That's an expensive timer. Remembers stuff for forty years! No need to replace it for a single speed motor. It has one timer circuit, you aren't even using.
   / Two speed Electric motor question #53
Interesting. So there isn't always a centrifugal switch?
Almost makes me think then, that it could be a failing start cap. But the motor shop tested it. Have them check the value of it specifically.
pool pump motors don't have a start cap, not that much torque is needed for the pump. just a centrifugal switch. so cross out the start cap.. you can make a saw or compressor motor out of a pool pump motor by putting a start cap in series with the centrifugal switch, though. it works great..
okay guys....an update - I think I am narrowing this down. Went through a few options again this morning - some repeated from before.
1)when I said it no longer worked on high speed that was because I had a loose line wire connection - likely because I did not retighten after one of my wiring dx changes. Discovered that this morning as I checked all the wires and now high speed works fine. So that info was misleading and confusing.
2) I tried low speed on all three of the control box circuits and all give me a moderate humming sound. Then I tried the high speed wire on all three of the control box circuits and have high speed working on each of the three buttons - so assuming the timer/control box is okay.
BUT now discovered this: While I cannot start low speed no matter which of the three timer circuits I use IF I have the pump running on high speed and then toggle to low (i.e., hit the low button after starting on high and while it is running on high) the pump will toggle to low and runs normally. I can toggle between high and low - back and forth - and get each speed - high on high button and low on low button. BTW the way the timer has always worked is that if it is running on one speed and you hit the other speed it just switches to that speed.
So, my lay person and technically uninformed assumption is that there is either too much resistance somewhere in the pump so that it can't get started on 'low', but once kick-started on high, low can manage to kick in. Or there is something within the pump (?) that is not functioning correctly. I am thinking it is within the pump because when I wire the pump directly - outside of the timer system - I still get the humming sound when trying low speed and it does not start.
Anyway if the motor is bad on low and would require expensive repairs or a replacement, I am content to set the timer to just run it on high.
AS always, thanks for all of your help.
Non running toro mower (A48082)
Non running toro...
2014 CATERPILLAR 2P5000 WAREHOUSE FORKLIFT (A51242)
2014 CATERPILLAR...
UNUSED AGT QK20R EXCAVATOR (A51243)
UNUSED AGT QK20R...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2014 Dodge 5500 4X4 Bucket Truck (A52128)
2014 Dodge 5500...
