ideburger
I was not successful at what I hoped to be a couple of quick fixes on my 861 today. First job was to replace a leaking power steering hose on the right side. What is the best way to access the fittings on the control valve? I considered pulling the hood off but that seems like quite a job. I also thought about removing the throttle rod that blocks view of the fitting and makes getting a wrench on it harder. I was afraid this may get something out of adjustment. Is there a better way?
Second job was to replace the friction disc and friction plate on the hydraulic control lever. It won't budge. I soaked it in PB Blaster and heated it up a bit with propane torch and it is still stuck. Should my next move be a gear puller? I finally gave up for the night after accomplishing nothing. Thanks for any tips.
