two problems....steering and sheer pins
   / two problems....steering and sheer pins #1
Toby873
Bronze Member
myakka city, Florida
Branson 4720i
4720i- The steering wheel, when turned to the left does not stop, I can spin it all the way around, it does turn the wheels but continues past the obvious full turn position. Operates norrmally and stops when turned to the right.
Shear pins on a Howse Medium cutter.....I have sheared mine because of a stupid procedural error on my part. I saw the pin fly out of the box, found both ends and the inner shaft part but my cutter continues to cut, shouldn't it spin and do nothing?
Toby
   / two problems....steering and sheer pins #2
<font color="blue"> Shear pins on a Howse Medium cutter.....I have sheared mine because of a stupid procedural error on my part. I saw the pin fly out of the box, found both ends and the inner shaft part but my cutter continues to cut, shouldn't it spin and do nothing?
Toby </font>
Toby, could it be held on the shaft because of rust ?? /forums/images/graemlins/confused.gif
nope, I had just greased both couplings and taken it apart to try and get a new shaft sleeve/guard so I had it off an hour before this happened. too late to work on it after getting home from 'real' job, if I unhook the 3 point hitch is it a bad thing to just use the tractor to pull it off?
Toby
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
1997 International 9300 Day Cab Tractor (A52384)
1997 International...
