Two Oil Fill Locations for Kubota RTV 1140
   / Two Oil Fill Locations for Kubota RTV 1140 #1
Farm All
BRENTWOOD
Kubota RTV 1140
One is on side of block, the second is on top of valve cover. Both caps are marked "Oil". Does it matter which one I use to refill after oil/filter change? Dumb question maybe, but have a nagging doubt and no manual to refer to.
   / Two Oil Fill Locations for Kubota RTV 1140 #2
It makes absolutely no difference.
Brian
thanks much.
   / Two Oil Fill Locations for Kubota RTV 1140 #4
Can not speak for Kubota but on Kioti, there are two as well but should only use the one on side because the top one drains too slowly allowing oil to enter the breather tube from top of head pan to intake manifold. It would seem as the drain holes in the diffuser over the valve head are too small and slows the flow down to the block.
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53472)
3-Point Hitch Root...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
7021 (A50322)
7021 (A50322)
GEHL RB1470 TOTAL DENSITY CONTROL HAY BALER (A51247)
GEHL RB1470 TOTAL...
