Twisted + bent rotory blades
/ Twisted + bent rotory blades #1
Von
Veteran Member, Advertiser
Western New York
Kubota B2710
I picked up a very used Howse rotory cutter 2 years ago for $175.00. Had to weld it back together and repainted it. It has worked fine ever since. The blades were alittle bent and had some twist to them, but for all the rocks I needed to cut in half I figured they were perfect for the task!/w3tcompact/icons/smile.gif Well I desided to check them for this year and wow was I surprized at how I beat them up! (see attached photo) So off to the new TSC that just opened last week, and of corse they don't sell Howse brand any more. So I picked up the King Kutter blades for $13.95 each. The manager thought that mine were the same blades, just mine were too bent to tell for sure. If anything they may hang down an extra 1/2" if that. Now can the old ones be straightened out any for when I loan it out to the neighbors? All I will be cutting now is grass about every four-six weeks, so I would like to put a real sharp edge to the new blades.
/ Twisted + bent rotory blades #2
I think that with a little heat, you could bend them back into shape, but you would likely take the temper out of the steel, and probably would just be better off getting a new set every year or so if you are really rough on them. I think that even if you did get them reasonably straight again, they would likely still be pretty out of balance, and would probably still wobble and vibrate alot.
As to the real sharp blades, I am not sure that you want to sharpen them too much, unless you are really sure that you will not hit anything but grass. With a thin sharp leading edge, anything you hit (like rocks, sticks, etc. will ding that blade pretty deep, usually making the blade cut even worse than one with a fairly blunt edge. Just my .02...
/ Twisted + bent rotory blades #3
Von, there's no doubt they could be heated, straightened, etc., but personally, I wouldn't do it; just wouldn't ever trust them again. I'd just discard them.
/ Twisted + bent rotory blades #4
The more times a peice of steel is bent or worked the harder it gets in that particular spot. So where they have been bent and then straightened several times, there will be an area that can easily become to hard, or brittle. And prone to crack easily. On a rotary cutter this can lead to a traumatic blade failure. some thing you really don't want to experiance.
/ Twisted + bent rotory blades #5
Kodiak,
For how mashed, bent, twisted, and dinged those blades are, I think that it would be hard to tell what the correct size may be.
Man - you beat the poop right out of them!! /w3tcompact/icons/crazy.gif
Terry
/ Twisted + bent rotory blades #6
Actually those blades belong to Von. I would have replaced them quite awhile ago.
/ Twisted + bent rotory blades #7
Von,
Howse is still in business. There was a thread about chain guards recently and people had had luck ordering parts from them. You could give them a call to check what the dimensions of the blades are supposed to be.<A target="_blank" HREF=http://www.howseimplement.com/>http://www.howseimplement.com/</A> Replacing the blades looks like the way to go to me. I would mount the old blades on the wall of the shop as a trophy.
Chris
/ Twisted + bent rotory blades #8
I havn't tried straightening bush hog blades, but straighten my finish mower blades on a regular basis. I do so without heating in a hydraulic press.
/ Twisted + bent rotory blades #9
It sounds to me like it's time to spring for new blades. I would not want to attempt straightening them for the reasons mentioned.
Blade failure under use, caused by fatiguing (bending/reshapeing) the steel may not be pretty; depending on where the projectile lands.
It would seem that if they were not "true" or "really straight" it would start up some funky harmonics in the gear housing and lead to premature wear. I would rather buy new blades than pay off on any of the above damages.
b249
/ Twisted + bent rotory blades #11
von : i would suggest u don't use blades that bent or out of balance, not only can they vibrate and cause damage to ypur cutter, but they can also be dangerous when they vibrate that much.$30 or $40 is not that much every few years for safe operation.
/ Twisted + bent rotory blades #12
Hi Von - I agree with Neal - COLD straighten the two best ones, sharpen them and keep them as spares - if any easily visible cracks have started, throw them out. BTW, heating them doesn't go anywhere unless you're a heat treater and you know all the alloy-specific specs on what temperature to bring them to, what to quench them with, and how to case-harden and/or temper them again to get all the desireable toughness properties back. Take care - Dick B
