TV Antennas?
/ TV Antennas? #1
PapaPerk
Veteran Member
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Hello, Planning to convert over from cable to free TV. Would like to pick up stations that are located 50 to 60 miles away.
Any advice on antennas and or amplifiers? Or general input on the subject?
Thanks guys! :thumbsup:
/ TV Antennas? #4
We have an outside antenna on a 34' tower. Tried one of those new round amplified antennas which does not work as good as the small size aluminum stick style antennas. Also got tired of the high bills from Dish.
/ TV Antennas? #5
When we built are house we put an outdoor antenna in our attic. I then connected it to the cable lines running through the house. We are about 30 miles from most of the towers and it works very well.
/ TV Antennas? #6
That is what I did back in 1974. Put the antenna in the attic hanging from nylon fishing cord. It worked perfectly for all the local Houston stations and no unsightly poles and wire hanging on the side of the house AND not fear of storms blowing it down. I dont think my wife would go for cutting the cable though even though there is only maybe a dozen shows that we watch and then only on DVR for the most part. Cant stand to watch all the stupid commercials today.
/ TV Antennas? #7
Maybe a bit off the thread topic, but what about us old-timers and our analog TV's. Is there an inexpensive (cheap) solution whereby an old but perfectly useable telly can be made useful again?
/ TV Antennas? #8
They were making digital converter boxes for making an analog tv able to recieve digital signals. Check radio shack, bestbuy, Sears, etc...
For us, it even worked with the analog antenna sitting on the tv, plugged into the converter box. We received over the airwaves digital channels...FREE.
U can do the same with a new all digital flatscreen. Ours still plays local analog stations...which are sometimes old fashioned fuzzy. Digital breaks up into blocks or shows black.
FREE TV... That's how I watch. :)
/ TV Antennas? #9
you could build a tuned dipole or yaggie ( ok.. folded dipole ... 1/4 or 1/2 wave..etc )
/ TV Antennas? #10
We also had our antenna in the attic. When we had a steel roof installed it killed our TV reception.
/ TV Antennas? #11
That is a helpful post!
We've been considering a metal roof. Sounds like that would kill free tv, with an indoor antenna. So, if we want metal roof, we need outdoor antenna...
Thanks for posting.
/ TV Antennas? #12
50 to 60 miles is really pushing that signal. Gonna take a very tall pole. Is your property on a high point? Line of sight is important.
/ TV Antennas? #13
I am in WV and my house is down in a valley. The ridge is about 800 feet higher than the house. i am using a Winegaurd antennae and with a rotor and a booster. All the channels I receive are about 30 miles away. I rarely adjust the rotor as all of the transmission towers are in nearly the same direction. The rotor was used before the analog to digital changeover.
/ TV Antennas? #14
How I would love to tell Comcrap to pound sand concerning their TV service; but I have yet to figure out a way to get cable channels over the internet reliably and most important...easily. I won't mess with satellite TV.
/ TV Antennas? #15
Thanks for posting.
When television was first being sold in our area [back in the 1950's] there was no cable service and some people bought antennas but some used other things as antennas but either way you couldn't get but one channel and by today's standards it was so snowy that you could barely watch it and the signal would fade in and out. One thing that we tried was a bicycle rim, and it worked just as good as the antenna that was bought at the stores. I mentioned the fact that we used other things as antennas to pose an idea do you think that maybe you could hook up your tv cable to the metal roof and be able to pick up anything. We used to use insulators on the wire to hang it up but I don't remember if that was absolutely necessary.
/ TV Antennas? #16
Here's my solution: a DTV converter with built-in recording to hard disk or writable DVD:
Magnavox 160GB HDD & DVD Recorder with Digital Tuner: TV & Video : Walmart.com
I think there's a newer model with a 500GB disk out by now. Both work like a manual version of TiVo, namely you can record, pause, and replay real-time TV, but you have to input recording times yourself as the device has no way of reading the channel listings.
/ TV Antennas? #17
Interesting idea. I do not have a metal roof as of now, but maybe the poster who mentioned that problem could try that idea... That would be cool to turn the whole roof into a giant antenna.
/ TV Antennas? #19
You will need a high gain parabolic UHF antenna mounted above roof level on a motorized rotor to be effective. This will give maximum coverage and included channels your didn't know you could get. I live 35 miles from Nashville and had Directv till I canned them. I used just some rabbit ears to pickup local weather during stormy conditions when my dish was having rain fade and loosing signal. With rabbit ear I was only able to pickup the strongest station, not all. The antenna I'm speaking of is not that expensive but adding mast and rotor, cable it could add up. One time fee though stations transmitting in HD will actually look better than cable. Don't forget to ground the mast and cable. See subject installing outdoor TV antenna on google. digital TV transmits in the UHF band.
/ TV Antennas? #20
Same as rabbit ears. :) I have made miniature quad beams in horizontal polarization for TV and it worked amazing.
