turning wheels around for more stance?
   / turning wheels around for more stance? #1
michaelTS354
North Carolina
Kama TS354C
On my TS354C i have been considering turning the wheels inside out for a wider track and more stability. My question is has anyone done that before? The way the wheels are dished it would make the stance considerably wider. The only problem i see is having to reverse the weights on the rear wheels also_On the rear it looks like i could just move the inner disc from the inside of the rim to the outside of the rim instead of swaping sides. Any suggestions or experiance is appreciated.
   / turning wheels around for more stance? #3
Check in your owner's manual. The one that came with my JM254s had a section devoted to adjusting rear wheel stance; four optional widths derived from various spoke and rim variations. The offset rims can bolt on either side of the spokes, and the spokes can be mounted convex or concave on the hub. Four combinations.
If you've got the standard one piece front rims though, I don't recommend you be tempted to reverse them - especially under a FEL. Wheel weights can be mounted inside or out, depending upon the configuration you choose.
//greg//
   / turning wheels around for more stance? #4
//greg//
   / turning wheels around for more stance? #5
If yuo dish the rears, make sure you keep tread facing forward.. that's why people swap sides.. etc.. ( poor mans 'power adjust /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif )
Soundguy
   / turning wheels around for more stance? #6
Soundguy
   / turning wheels around for more stance? #7
</font><font color="blue" class="small">( On my TS354C i have been considering turning the wheels inside out for a wider track and more stability. My question is has anyone done that before? The way the wheels are dished it would make the stance considerably wider. The only problem i see is having to reverse the weights on the rear wheels also_On the rear it looks like i could just move the inner disc from the inside of the rim to the outside of the rim instead of swaping sides. Any suggestions or experiance is appreciated. )</font>
Hey Mike,
I wanted to flip, my front wheels around, to get a wider stance, but so many advised against it, that I didn't do it. Most said, that it just puts too much stress, over all on the Front End, so I didn't do it on my 224.
Have a nice day,
Joe /forums/images/graemlins/cool.gif
   / turning wheels around for more stance? #8
Hey Mike,
Have a nice day,
Mine does have the one piece front wheels so i believe I will just space the rears out and leave the fronts alone. Thanks for the help.
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53473)
JOHN DEERE ROW...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
Year: 2008 Make: International Model: 4300 Vehicle Type: Truck Mileage: 141781 Plate: Body Type: (A51692)
Year: 2008 Make...
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
