Turning radius for BX1500/2200?
   / Turning radius for BX1500/2200? #1
smartguyz
Beaverton, Oregon
JD318, Power-Trac PT425 with scuffed-up green paint.
Hi, do you guys know the turning radius for the BX1500 and the BX2200? I am shocked by the advertised turning radius of the JD2210. Their website says the JD2210 turning radius is 7.5 feet!
How does the BX stack up?
-Rob /forums/images/graemlins/confused.gif
   / Turning radius for BX1500/2200? #2
My bx22 has a 7.5' min. turning radius also.
   / Turning radius for BX1500/2200? #3
I gasped at the 7.5 foot turning radius also. Now that I have used my BX for five months it is not the issue that I thought it would be. In fact it handles very nicely around shrubs and other obstacles.
John
   / Turning radius for BX1500/2200? #4
There are several older threads on this under Kubota. The turning radious for the tractors is being measured differently from that of your riding mower, tractor styled though it may be. The actual uncut radius using a 60 inch MMM on a BX is about 32 inches or so I think, yeah, that huge deck on the outside and the outer front wheel may scribe an arc nearly 7 feet or so in diameter. These tractors are actually very manuverable especially given their size. I suspect you will find the JD/Yanamar 2210 unit equally manuverable to the Kubota BX 2200.J
Electric Mobility Scooter (A51694)
Electric Mobility...
5ft Set of Disc Harrows (A51573)
5ft Set of Disc...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2013 RAM 4500 (A50323)
