Turning Plow Potato Plow middle buster
   / Turning Plow Potato Plow middle buster #1
armyret
Monroe County WestVirginia
Kubota B7800
Do you shorten or extend the top link to plow deeper I am suffering from memory loss for I know this and have not forgot.
   / Turning Plow Potato Plow middle buster #2
I'd shorten the top link to make the point turn downwards more. Lower the 3 pt to the lowest point and I reckon that will be as deep as it'll go. I have some pics of using my middle buster to sink some 4" corragated drain. Worked pretty well. Sure beats the hickory Backhoe.. Check them out under my tractor album section.
http://users.adelphia.net/~gizmo/
   / Turning Plow Potato Plow middle buster #3
I just bought and used a middle buster for the same reason. Dug about 3' by hand and then stopped at the farm store on the way home the next day. Best $107 I ever spent!
Now I'm looking for a narrower sweep. May just buy the KK one and cut it down.
   / Turning Plow Potato Plow middle buster #4
</font><font color="blue" class="small">( Now I'm looking for a narrower sweep. )</font>
How narrow? I bought a single big "tooth" made for a really big chisel plow at Tractor Supply Co. and sometimes bolted it on in place of the plow share. If I remember right it was only 2" wide.
   / Turning Plow Potato Plow middle buster #5
Just bought a potato plow last year,,and guess what I used it for,,I plowed my potatoes,worked great,,for that I lowered it,made point level with ground,than shorted up top link a little to dig in,,don't need much for potatoes,,,if you put it on float,it will dig in by it self,,be doing it again in a couple of weeks,,,,thingy
   / Turning Plow Potato Plow middle buster #6
Bird,
Maybe 2" or 3". I looked at what they had a Orschlens, where I bought the middle buster, and they had sweeps but the bolt holes didn't match up. Want something I can use to bury 3" plastic conduit. My wife says I need to bury the coax that will run to my ham radio antennas.
Could use the sweep that I used for the 4" plastic drain pipe but don't need a hole that wide.
   / Turning Plow Potato Plow middle buster #7
Try getting yourself a plow point called a "corn plow." Mine is about 4" wide, and the holes line up fine. As a matter of fact, one of the holes is elongated to give a little flexibility.
2019 Freightliner M2 106 18ft Landscape Dump Truck (A50323)
2019 Freightliner...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2005 Nissan Titan (A50120)
2005 Nissan Titan...
