turning peddle on 4200 jd
   / turning peddle on 4200 jd #1
ohrider
sunbury, oh
4200 jd
When I press either left or right turning peddle they will not release that wheel. This is a hydrostatic tractor.
   / turning peddle on 4200 jd #2
I am assuming that you areceived talking about the individual brake pedals? If so check where the brakes linkage rods go into the axle housings. The dissimilar metals cause corrosion and the the rods stick. Lube up the rods and use a pry bar to get the linkage to release. May have to work with them to get loosened up. The hydrostatic tractor do not seem to get the brake pedals used much.
Thanks for all the help. I think I can find the issue from all the good information I have received.
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A54865)
INOP/NON - RUNNING...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2016 KOMATSU D65PX-18 BULL DOZER (A55745)
2016 KOMATSU...
2013 RAM 4500 (A50323)
