turning peddle on 4200 jd
   / turning peddle on 4200 jd #1
ohrider
sunbury, oh
4200 jd
When I press either left or right turning peddle they will not release that wheel. This is a hydrostatic tractor.
   / turning peddle on 4200 jd #2
I am assuming that you areceived talking about the individual brake pedals? If so check where the brakes linkage rods go into the axle housings. The dissimilar metals cause corrosion and the the rods stick. Lube up the rods and use a pry bar to get the linkage to release. May have to work with them to get loosened up. The hydrostatic tractor do not seem to get the brake pedals used much.
Thanks for all the help. I think I can find the issue from all the good information I have received.
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
New Three Point Hitch Trailer Mover (A54865)
New Three Point...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
62 (A52706)
62 (A52706)
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
