Turning off the service indicator light
/ Turning off the service indicator light #1
LaVita
Oregon
Kubota L4330, JD LX188
Hi,
Just did my 100 hour service. Can somebody tell me how to turn off the dashboard service light (the lit up wrench)?
Thanks,
Chuck
/ Turning off the service indicator light #2
With all due respect, if you have read your owner's manual to learn what to do for the 100 hr. service, didn't you notice that it tells how to turn off the light? Don't know what model you have, but the manual for our L3830 explains it.
Nope, didn't see it. I will look again.
Chuck
/ Turning off the service indicator light #4
If you can't find it in your manual, ours cancels by holding down both buttons on the dash.
I did find it and it is the same, both buttons while in hours mode. It's actually in a different part of the manual. Its in the Intellipanel part of the manual not the service/maintenance part.
Thanks again,
Chuck
/ Turning off the service indicator light #6
Hey Guys,
I'm not sure what's going on but my light won't clear on my 3430L Grand? Any ideas? I hold th buttons down in any mode and the light won't clear. Thanks.
/ Turning off the service indicator light #7
Jamesbo said:
Hey Guys,
Hehe...:D remove the bulb. Dad gum fancy electronics on a tractor!!
/ Turning off the service indicator light #8
Not a bad idea Rob]!
Fancy shmancy electronics.
Could be the operator I guess. Maybe I'm not holding my jaw just right and my fingers on the correct buttons at the correct time? I don't know, they call it a IntelliPanel, not an Intelli-Operator. :-(
/ Turning off the service indicator light #9
Jamesbo
From memory, for my model, you must have the Intellipanel in HOURS mode (where you see the number of operational hours) and THEN press and HOLD BOTH the buttons down simultaneously for two seconds. Then the wrench goes away.
I haven't done a scientific study, but my belief is that the SERVICE INDICATED light (wrench) comes on at EACH 50 hours.... not 50 hours from the reset point, but everey 50 hours... so, it may turn on "early" for the next service.
/ Turning off the service indicator light #10
Thanks for the info TexasJohn.
I will try it again, but I thought I did just that. The light has been on for quite awhile now, maybe it need to be cleared several times before it goes out. Thanks
/ Turning off the service indicator light #11
Hmm... seems to me that the engine should not be running... but the key turned on so you see the panel... not sure if I am remembering correctly.....might give each way a try see if that works for you.
/ Turning off the service indicator light #12
Good Idea. I'll try it both ways. Thanks much.
/ Turning off the service indicator light #13
Ok guys, I got it now. It was a user problem of course. I misunderstood things a bit. You gotta toggle to the hour meter and then simultaneously hit both buttons at the same time and hold for a few seconds. You can't just hold the hour button down and then the other. The keyword here is "simultaneously". The sevice light is now off. Ahhh...lifes simple victories. Thanks for the input. :)
/ Turning off the service indicator light #14
Yep, happiness is having no messages on your Intellipanel:D
Congrats.... now, you'll remember it..The first time is the hardest.
2016 John Deere 6130R (A64126)
2016 John Deere...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
