Turnbuckle Play
   / Turnbuckle Play
John, thanks for your input but unfortunately, even with the turnbuckles fully cranked down (threaded sections fully enclosed in the body) I still have too much play. I'll experiment with some of the suggestions offered and see if I have any luck. I'll keep you all posted post deer season (gotta have some priorities in life). Happy Thanksgiving to all.
   / Turnbuckle Play #12
John,
There is something wrong. Either the implement is to narrow or the sway links are mounted wrong. Measure between the swivel balls with the links tightened all the way. Do this while holding the arms as close together as possible. The measurement should be somewhere around 26" give or take an inch.
   / Turnbuckle Play
Let's close this one down guys. I bought shorter stay chains (through E-Bay for about $40 incl shipping) and it solved the problem. I had to move the set up to the next hole due to the shorter length, but it works like a charm. Since I got the machine well used, perhaps someone substituted turnbuckles that were too long? I'll never know but now don't care and trust I won't miss the sound of the loop rings biting the tires. Again, thanks to everyone for their advice and comments.
   / Turnbuckle Play #14
Can you provide a link to the chains you bought on EBay?
   / Turnbuckle Play
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
flooring (A55758)
flooring (A55758)
HUM V (A58214)
HUM V (A58214)
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
NEW Long Forks (A59000)
NEW Long Forks...
