Turn signals glow
   / Turn signals glow #1
marq
Romeo MI
03 JD 2210
JD 2210, had to leave the big baby out for a couple nights while we re-did the garage floors, and yes it rained one day. Now the turn signals do not work, the dash indicator just glows, all other lights work.
Assume a flasher. Any idea where it's located?
   / Turn signals glow #2
What makes you think it's the flasher?
Sounds more like water in the switch to me or some other spot it's not supposed to be. You try using an air gun to blow out the switch and any other possible areas?...............Mike
   / Turn signals glow #3
Agree with mrmikey above.....I'd just let it air dry for a few days before messing around with anything.
   / Turn signals glow
That was my original thought but it's been two weeks back inside, no change!
Plus from the switch to the lights the flasher is the only device, if something shorted it would be the most likely candidate.
   / Turn signals glow #5
I agree, you'd think after two weeks whatever moisture would be gone unless it's partially corroded the contacts or even the plug together. Wonder if you take some electrical contact cleaner and spray around the switch and plugs?
This help any for location of flasher:
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Ford Pickup NR (A50323)
Ford Pickup NR...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
Brent 420 Grain Cart (A55301)
Brent 420 Grain...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
