Turn signals glow
   / Turn signals glow #1
marq
Romeo MI
03 JD 2210
JD 2210, had to leave the big baby out for a couple nights while we re-did the garage floors, and yes it rained one day. Now the turn signals do not work, the dash indicator just glows, all other lights work.
Assume a flasher. Any idea where it's located?
   / Turn signals glow #2
What makes you think it's the flasher?
Sounds more like water in the switch to me or some other spot it's not supposed to be. You try using an air gun to blow out the switch and any other possible areas?...............Mike
   / Turn signals glow #3
Agree with mrmikey above.....I'd just let it air dry for a few days before messing around with anything.
   / Turn signals glow
That was my original thought but it's been two weeks back inside, no change!
Plus from the switch to the lights the flasher is the only device, if something shorted it would be the most likely candidate.
   / Turn signals glow #5
I agree, you'd think after two weeks whatever moisture would be gone unless it's partially corroded the contacts or even the plug together. Wonder if you take some electrical contact cleaner and spray around the switch and plugs?
This help any for location of flasher:
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55218)
LIKE NEW 2023...
2001 New Holland EC215 Hydraulic Excavator (A52377)
2001 New Holland...
10ft Inclosed trailer (A53424)
10ft Inclosed...
2018 International DuraStar 4300 TMA Attenuator Truck (A52377)
2018 International...
