TURN Signals and flashers don't work
   / TURN Signals and flashers don't work #1
JWalls
RK25
For whatever reason, my Hazzard lights and turn signals stopped working. I can here the relay clicking when I use the turn signal, but nothing when the Hazzard lights are activated.
This is on a RK24
   / TURN Signals and flashers don't work #3
You could try replacing the flasher. I prefer the newer solid state ones to the old mechanical switch type.
   / TURN Signals and flashers don't work #4
Check wiring also.
   / TURN Signals and flashers don't work #5
I finally got my flashers and turn signals working, the sockets were corroded badly and the pressure springs couldn't move. Spray penetrating oil and patience fixed them.
   / TURN Signals and flashers don't work #6
Glad you found the problem. I was going to suggest someone might have stuck a BMW logo onto your tractor, and you didn't notice it.
Bruce
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
John Deere 50 (A60462)
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
