TURN Signals and flashers don't work
   / TURN Signals and flashers don't work #1
JWalls
RK25
For whatever reason, my Hazzard lights and turn signals stopped working. I can here the relay clicking when I use the turn signal, but nothing when the Hazzard lights are activated.
This is on a RK24
   / TURN Signals and flashers don't work #3
You could try replacing the flasher. I prefer the newer solid state ones to the old mechanical switch type.
   / TURN Signals and flashers don't work #4
Check wiring also.
   / TURN Signals and flashers don't work #5
I finally got my flashers and turn signals working, the sockets were corroded badly and the pressure springs couldn't move. Spray penetrating oil and patience fixed them.
   / TURN Signals and flashers don't work #6
Glad you found the problem. I was going to suggest someone might have stuck a BMW logo onto your tractor, and you didn't notice it.
Bruce
2017 Peterbilt 567 Tri-Axle Dump Truck (A48081)
2017 Peterbilt 567...
2011 Ford Ranger 4x4 Ext. Cab Pickup Truck (A48081)
2011 Ford Ranger...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
Gooseneck Trailer Hitch (A50860)
Gooseneck Trailer...
197910 (A51242)
197910 (A51242)
