Turn Signal Draining Battery
   / Turn Signal Draining Battery #1
Nativetexan_1
Kioti ck3510
Right turn signal stays on 24/7, at least until the battery goes dead. What would cause it to receive power with no key and turn signals turned off? Temporarily, I have installed a battery cutoff switch.
   / Turn Signal Draining Battery #2
You may have a defective turn signal switch - internal damage. It may also be your flasher. Many vehicles are wired such that the four way flashers may be enabled with the key off. If the turn signals use the same flasher you have a possible source for your problem. Get an electrical schematic and track down the circuit. Oh, and welcome to TBN.
Thanks for the info.
   / Turn Signal Draining Battery #4
You must go to work the same way I do everyday... oh wait, this is on your tractor? 😂
Welcome to TBN!
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
Case 586E Rough-Terrain Forklift (A52128)
Case 586E...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
