Turn a field into a yard
   / Turn a field into a yard #1
rookiefred
NW Davie County, NC
Kubota Grand L3240
Advice requested.
I have about 10 acres that has been no till drilled forever and would like to turn part of it into a front yard around where we are going to build. Some think it needs to be turned, some think just disking will be good. I'm leaning toward tilling. It has some deep ruts and something needs to be done. I have the time to till, it does not all need to be done right away. Turning 8" is the recommended depth when I explained all this to the Kubota salesman. A good size tiller will do that or close to it. The most I'll probably do with the 10 acres is a garden and have thought about tomatoes (if I can keep the deer out) to sell to the local market. A salesman at Southern Farm Supply in Union Grove, NC heard that an electric fence with peanut butter works pretty good for deer. Any preferences on a brand of tiller? Southern beat every one for a Southern standard duty 6' box blade. They carry Howse tillers. Thanks for any advice.
Rookie Fred
   / Turn a field into a yard #2
I've had better luck when I till shallow on the first pass to cut up the sod then go deep on the next one. I've got a Bushhog tiller I've pounded and rebuilt a couple of times.
   / Turn a field into a yard #3
I would disk rather than till. Tilling will take a lot of time. When you say it was no-tilled, was it for crops? Sow your grass seed around August or September. Doing it now will get you a stand but you won't have enough root to get through the summer heat.
   / Turn a field into a yard #4
I would rototill it. Over all time is less because tiller makes such a good seed bed. I recommend King Kutter Heavy Duty tillers. They are gear driven. Have many tines (installed in a twisted orientation along the main shaft).
Going 8" down sound kinda deep. I would go around 5" deep with the tiller. Make sure to let the rain settle the dirt real well.
After you use the tiller for planting grass you can use it in your "mater" garden! :)
I have a KK 72" tiller that I run with my Kubota 3830. Works great!
   / Turn a field into a yard #5
I would till it deep as you mentioned, then plane it smooth, seed it heavy with a broadcast seeder, then cover with a harrow and roll it.
Here is a pic of my lawn and the custom landplane with harrow.
The field has had soybeans and last year, rye. You're right about the heat, but I have the time to do it. I'm mainly concerned where they will be putting the septic field (in front of the house) and my guess it it's probably not a good idea to till over it after they get it installed. Won't disking require additional steps, such as possibly disking more than once and using a drag harrow? The neighbor across the road said he has lived there for 12 years and he does not remember it ever being turned, disked, etc.
Fred
WOW! That's what I'm looking for! I can only hope what I'm trying to accomplish will look that good! Awesome job.
There's been posts about the plane in the Kubota area. I think Land Pride changed the name from a land plane to grading plane. Talk is the plane works well on gravel driveways. You gotta love a dual purpose tool.
Thanks
   / Turn a field into a yard #8
rookiefred, sorry but I just have to ask the question.... why would you want to have to mow 10 acres of grass on a regular basis?? Don't get me wrong, I'm all for seat time but that just seems to be overdoing it. Have you thought about how much time it will take to keep 10 acres mowed, once or twice a week, depending on how much rain you get? What do you have to mow it with, assuming you get it growing nicely? I say fence it in and put some goats, cattle, or horses in there! ;)
   / Turn a field into a yard #9
I wish the previous owner of my place would have at least disced it up after row crop prior to pasture. It will just about beat you to death mowing across the rows or whatever plus the cows tramping in it didnt help. I am going to have to disc it several times and then drag a harrow over it to get the humps and valleys out of mine where I have taken in some pasture for a yard. NOT 10 acres but likely about 3. That is my next chore. Then of course have to pick up the new crop of rocks that turning up the soil will uncover. Since I dont currently have a harrow, that is another piece of equipment I need to buy.
   / Turn a field into a yard #10
Oh yeah, some advice on electric fences for deer. According to my brother who is an avid deer hunter, to keep deer out of your place, put the wire about 1 foot off the ground. He said deer travel with their heads down grazing and when they hit the fence with their nose, the may rip it out of the ground when they jump about 10 feet in the air, but the wont be back again. Depending on how many deer you have, I guess depends on how many fence repairs you have to do. He did say that if you put it up like you would for cows, they will see it and just jump over it.
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2014 DRAGON PRODUCTS STEPDECK 46 DOVETAIL W/RAMPS (A53843)
2014 DRAGON...
