Turn a 25D into a 33D?
   / Turn a 25D into a 33D? #11
</font><font color="blue" class="small">( Of course, my memory is faulty on occasion. )</font>
Yep, I remembered it wrong. Seems to be happening more often these days. /forums/images/graemlins/frown.gif
   / Turn a 25D into a 33D? #12
I don't know about the 25D and 33D engines, but I've found that it is reasonably common to put out different models that have the same engine with different power ratings, and the only differences are simple adjustments. A good example is the TN55 and the TN65. All you need to do to turn a TN55 into a TN65 is crank up the pressure and flow on the fuel pump. It's just one screw and it takes less than a few minutes. I had heard that this was possible, and today I talked to a very credible source in NC that verified it - and noted that it was one of the reasons that NH is discountinuing the TN55... Too bad I didn't get on the ball earlier, because there were some sweet deals on the discontinued TN55's a little while ago. I saw new ones for $14,300.
I used to teach a class on automotive engineering and IC engines, and it was always fun to show how much easier it is to improve the efficiency and power of diesel engines compared to gasoline engines. In general, if you see two vehicles with the exact same engine model that are rated different, it won't take much to up the power. All you need to do is figure out how to get more fuel into the combustion chamber or up the governor speed.
   / Turn a 25D into a 33D? #13
"So, how do I get that extra 200 rpm?" .................. BIG turbo ??? A whistling TC25 would be really cool !!!!
   / Turn a 25D into a 33D? #14
Funny you should mention that. I just got back from a school in Sacramento about the new TSA tractors. Some of the engines the New Holland will be putting in thier tractors (80 - 115 PTO HP) will be the same engine that Dodge uses in thier trucks. Cummins, New Holland, & Ivetco partnered to build engines that all three will use. So I asked the question about the chips that people use to increase horsepower in thier trucks and will it do the same on the tractors. All he would say with a grin is that it is the same engine.
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
