Turfs vs bar turfs
   / Turfs vs bar turfs #1
TigerfaninAR
Central Arkansas
Kubota B2320 FEL, MMM
See discussion all the time over the most common type of tires but what about the bar turfs; where do they fit into the mix?
About ready to pull the trigger on a new b2320 and found these are an option. Was leaning towards the turfs because my property is a little low and the yard can be a little soft in spots plus it will be used mow 80% of the time. Will have some loader and box blade work.
Thanks, did a search on my phone and didn't see it.
Interesting and the ones that have them seem to really like them. I like the sound of a little wider tire to help out on the lawn.
   / Turfs vs bar turfs #4
I had bar turfs on an old Deere 670. I really liked them.
(BTW, I said basically the same thing in a post in the thread Triple R linked).
But they are not mud tires, so don't go running in some wet field expecting to pull a plow. Good tire that's a bit more aggressive then a turf but won't tear up your lawn if you use your tractor to mow.
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2015 TOP HAT TRAILER 18 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
JLG 1255 Telehandler (A53473)
JLG 1255...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
John Dozer JD650 (A51691)
John Dozer JD650...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
