Turf tires on front with ag rears?
   / Turf tires on front with ag rears? #1
jgarfield
RI
Kubota BX23
I have a Bx23 with ag tires front and rear. I remove the fel and bh to mow, but I'm finding that I am tearing up the lawn wherever I have to make sharp turns. It seems that it is the front tires that are doing the damage so I'm wondering if I should just change the fronts to turf tires and leave the rears as is? Anybody done this? Any disadvantage other than not as much traction with the fel?
Thanks,
Jim
Thanks,
Jim
   / Turf tires on front with ag rears? #3
The disadvantage will be that the tires will not be the same size, and when using 4WD can cause a problem with the lead-lag ratio between the front and rear tires. This can lead to damage of the drive train.
You would need to purchase the proper sized industrials for both the front and the back.
If you're using front wheel drive, turn it off and you should get less damage. I doubt you'll be able to completely eliminate it, but not using 4WD should help.
John
   / Turf tires on front with ag rears? #4
John
   / Turf tires on front with ag rears? #5
A lot of old farmers around here use plain old truck tires on the front.
   / Turf tires on front with ag rears? #6
   / Turf tires on front with ag rears? #7
</font><font color="blue" class="small">( A lot of old farmers around here use plain old truck tires on the front. )</font>
That's fine for a two wheel drive tractor, but the ratio between front and back tires is set for certain tire sizes when using 4WD.
Here's a link to a good article explaining lead/lag.
Lead/Lag Firestone
   / Turf tires on front with ag rears? #8
Lead/Lag Firestone
   / Turf tires on front with ag rears? #9
If he replaced the Ags with turfs of the same circumference, would that not be okay?
   / Turf tires on front with ag rears? #10
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
1065 (A53342)
1065 (A53342)
Bradley Electric Smoker and Cover (A51573)
Bradley Electric...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
